Two ways" Jim Markle's bending Pietenpol horn bends and My Method Like many builders, I really had no clue how I was going to make the formed control horns. Fortunately over the years I had gleaned enough information from other builders to be ready to give them a try. My first attempt was to simply make two bends. In the following pictures you can see the bends making facets not a smooth curve. Though it wasn't exactly like the plans I thought it turned out ok However, someone said they though I could do better. Well, who could turn down such a challenge. My next attempts match the plans much better and wasn't that difficult. Like every thing on this plane it just takes time. Here is how I do it. These are the tools I used After cutting out the horn I first drill the holes on the ends and make the cuts for the flanges that need to bend out. As you can see I didn't do so well at following my line on one corner. I fixed it by drilling the hole a little larger.
Time to form the end radius
On the plans you will see there is a brace that extends off the back of the horn. The only way I could figure out how to get the metal strip into the horn was to form a jog. I formed this jog over a piece of steel 1/2 the thickness of the brace.
Time to weld I used a lot of clamps to hold the two halves together. Because the metal is so thin I used a 1/16-inch welding rod sparingly. On the trailing edge I simply fusion welded, no added filler rod, because the two halves are almost parallel to each other. Finally, finish off the mounting flanges and bend the brace to fit your plane. |
