Propeller Carving
Up
Varnishing.jpg (556670 bytes)1-1-10, 1.jpg (594996 bytes)Balancing.jpg (562964 bytes)Before drilling Hub, 2.jpg (610341 bytes)Cable balance.jpg (570792 bytes)Center hole cut.jpg (624582 bytes)Chain saw cuts.jpg (605800 bytes)
Checking with Guage at Stations.jpg (590908 bytes)Chiseling between Stations.jpg (645746 bytes)Cutting profile on  band saw.jpg (553162 bytes)Guaging the shapes.jpg (630694 bytes)IMG00064-20100830-1539.jpg (54906 bytes)Knocking out chips.jpg (596872 bytes)Laminating Prop, 1.jpg (573100 bytes)
Laminating Prop, 2.jpg (565446 bytes)Marking stations.jpg (545610 bytes)More balancing.jpg (569478 bytes)Profile cut.jpg (566258 bytes)Prop bolts drilled.jpg (563358 bytes)Prop mounted, 1.jpg (586494 bytes)Prop with face plate.jpg (572260 bytes)
Rough cut.jpg (614918 bytes)Taking off excess with spoke shave, 2.jpg (589962 bytes)
