Mike Cuy
I purchased Comet brake calipers at a local lawnmower/ go-kart shop http://www.hoffcocomet.com/comet/aftermarket-brakes.asp (scroll down when you get there) and traded aerial photos of a machinist friend's home for him to turn some rotors that fit my wheel hubs. My wheels are 19" and my rotors are 6" in diameter and the Comet DC Series caliper just hold me for run-up and no more---which works out fine. As you've seen my plane at Brodhead, I made up heel brakes ala Cub/Champ and actuate the calipers with 1/16" cable. Lots of ATV brakes out there too now which I'm sure would be worth looking into depending on what suites you. Mike C.
Don & Group, Yes, the smoke setup I have is still as per original idea and is about as simple and reliable as you can get. I use a 2 quart poly pump-up bug sprayer from the Wal Mart garden department, hacksaw off the plastic handle, remove the spray wand and discard and adapt 1/4" plastic airspeed tubing to the sprayer nozzle with rubber hose and either tye-wraps and or hose clamps. The 1/4" poly line is connected to a 1/4" copper, stainless, or aluminum tube which connects to a fitting (mine is a Swaglok fitting) that you weld into one of your aft exhaust pipes (they run hotter than the fronts on 65 Continentals) about 1-2" down from the flange. On the ID of the fitting that is welded to the exhaust pipe you drill two No. 60 drill bit holes in your exhaust pipe wall and whala, you have a smoke system. (I suppose you could drill one hole with the same equivalent area but have not tried that) Might want to put a vibration loop or two in your metal tubing from the firewall to your exhaust stack to dampen the stresses and strain on the tube so your metal doesn't fatigue. The smoke oil I use is Texaco Canopus No. 13 which is basically a mineral oil. They used to call it Corvus oil. Every other year the Thunderbirds park at our NASA hangar when they are in town and I salivate beyond measure when I go up there and see beyond the cyclone fence about a dozen 55 gallon drums of the smoke oil ready for the Thunderbirds to use in our airshow. Mike C.
