My bench was built using two solid core doors (used $15), some 2x4s and
some 1x4s. Not shown in the picture are braces between the two
doors. This helped tie the two benches together and made them much more rigid.
Continental A-75 3hr SMOH by Tom Emery (RV-6 builder)
Sand Blasters,
Both are home-made boxes with a siphon feed gun.
Turned out to be to big to store in my garage so I got rid of it. Guess I need a
bigger garage.
I was desperate to blast the tail wheel so I built this with stuff I had lying around the garage. It consists of a blue plastic tub, I think its 20 gal. Hole cut in lid is covered with Plexiglas protected by Saran Wrap plastic film. Duct tape it on the lid. I used my welding gloves as they are the only thing I had. They actually work well at sealing the holes when the vacuum cleaner is attached. Cut a hole high in the back for the hose to attach to it. I loose a bit of blast media but oh well.
Sandblaster #3
Best one yet.
